- Joined
- May 9, 2015
- Messages
- 294
- Reaction score
- 56
- Age
- 73
It does show current, but only shows several ranges of 5A for the current. This makes me think that this is being calculated from the maHr figure, using a lookup table, and is only very approximate. I don't believe that there are any actual current sensors, because of their I2R losses. However, there are other ways to do this with solid state sensors, and one turn of wire. Can you hear me DJI?If you upload the flight log from your controller to healthy drones it will show you the battery current under load throughout the flight. The most accurate way to check usable capacity is to monitor mah returned to the pack while charging, the smart board in the battery logs this. You can find it in Healthy drones as last recorded mah.
