P3 Professional single shot, HDR and AEB little difference when processed
Anyone seen any major difference in HDR vs regular shots? I process all bracketing and HDR thru Photomatix and Lightroom and for the life of me all photos look the same, even when combined with the 3 or 5 AEB. Bracketed photos have difference exposure but just seems like theres little difference in the photos when in post. Anyone know if manual settings will override the HDR and AEB or use the exposure set by user? I use manual settings but overall i just dont see a difference. Am i missing something? Thx guys.
HDR is really best for high dynamic range subjects and if you use HDR to shoot these you will see a big difference. If you use HDR on a regular, or even low dynamic range subjects, you will not see much difference then just shooting RAW or even a jpeg.
High Dynamic Range means extreme contrast range. Try using it on a subject where you are looking into the light, with dark shadows and a very bright shy. For best results the bracket should be set to about 2 stops different (or more) for each frame, ie: 1) regular Exp 2) Two stops under 3) Two stops over.
Reactions: Cerone
Bracketed photos have difference exposure but just seems like there's little difference in the photos when in post.
EPT160 is right about the subject and lighting having an effect.
You can confirm that you are getting different exposure values when you shoot AEB by looking at the Exif data for each photo
Unfortunately you are stuck with a 0.7 stop difference between photos with the P3
That's a bit of a shame, 2/3 of a stop does not really make much of a difference for HDR. I have not used for aerials so did not check. Is it any different with Litchi do you know/
As @EPT160 said above, you need a high contrast image in order to see the benefits.
Thanks guys. I've been mostly focusing on real estate photography and static houses obviously do not offer a lot of high contrast opportunities. Too bad the .7 stop is so minimal.
When we implement HDR in our app it will be 7 images +3.0ev, +2.0ev, +1.0ev, 0.0ev, -1.0ev, -2.0ev, -3.0ev for the Inspire and P3P. With the P3A you can only go to + or - 2.0ev so that would be 5 images. The feature is a tad buggy for us at the moment but here are two sample shots I took with our app.
1440612651687
1440612600324
Reactions: apsphoto
jeetbuzz360
