p3 pro camera instalation
i bought a p3 pro and the p.o. said it has a bad flex cable...he had already taken the gimbal apart and i'm not sure how to get it back together...where the camera slides onto the shaft there is a flat spot on the shaft...which way does the cam go on the shaft?..if anyone knows i'd appreciate some help..thanks in advance
Reactions: SilverStone641
Auag, I just recently replaced the whole camera on my pro. I lined up the screw on the gimbal arm with that flat spot on the motor shaft. Once tightened it should work perfectly. Just don't forget to leave yourself a little space between the gimbal arm and the circuit board to slide that metal plate back over it. You want to be sure it doesn't bind up on the plate at all. Good luck!
