P3 Battery Voltage Question
I'm try to learn as much as I can and specifics about the battery... which I know least about.
I know that all the cells voltage should run close to the same level. I've been told that if a lone cell drops or is significantly lower...that's a sign of trouble.
The attached is the stats from a new bat I got about 2 days ago. Voltage is what I would call "in the ball park" but wanted to be sure.
Other batteries I have seem to to be closer if not exact equal voltage across the board.
Could someone please tell me if this reading is ok and that I should calm down and eat some fruit or something.
What is the tolerance or degree of difference where one should start be concerned?
Thanks much.
Now, more importantly... are you going to share that fruit or what? :D
jeetbuzz360
