P2v+ 5 red flash when trying to csc after crash
Sweden
Hello,
I have a p2v+ And crash it ....
Now it goes to ready mode (im in door so i have yellow flash)
when i try to csc i get five red flash then back to yellow flash .. and no motors starts ..
I cant find any info about the five red flashes ..
Any one knows the error?
Br
danjan
Hook to PC ASSISTANT,
Check your IMU readings:
Gyroscope
Accelerometer
Compass
Look at MOD values of each, read below:
IMU= Inertial Measurement Unit
( takes readings from ( gyroscope, accelerometer, & compass )
It takes the values and creates a MOD VALUE for each.
MOD= MODUUS
( another term for absolute value )
Basically goes like this:
Gyroscope SHOULD BE : ( 0.0 - 1.5 )
Accelerometer SHOULD BE : ( .98 - 1.02 )
Compass SHOULD BE : ( 750 - 2250 )
If any numbers above are OFF, perform a ADVANCED IMU CALIBRATION.
Also run a Tx ( controller ) calibration while you are still in PC ASSISTANT.
Do a FRESH COMPASS CALIBRATION before first flight! All should be well.
Take care, Fly safe!
Hi, All IMU was ok..
I open the body and find the connection from gps to main board was wery loose .. so i pressed it to mainboard and now will the motors spin on csc
I need to find a spare connector and replace it from the gps cable
intertronixlabel
