osd mini problem solved!
With all the hassles I've been through to make it work, there was one itty bitty item that was overlooked.
On the FPV hub in one corner there is a tiny switch.
One side marked as "vx" and the other as "iosd".
When using the iosd and the hub, the switch must be in the iosd position.
Now the information displays on the screen as it should.
If this bit of information was noted in the instructions or manual, I certainly did not recall it.
Agreed, it's buried in the graphic of the various wiring diagrams. No real text instructions.
