Ok, I am stupid
Ok I'm stupid but I've been using MS products forever...trying to install V2.16 installer, I get the following message: "Windows cannot access the specified device, path or file. You may not have the appropriate permissions..." Opsys is Win7, 64 bit. After downoading new updates, I no longer have the NAZAM Assistant, nada zip, etc.
Suggestions are welcome and will be appreciated
you have to download the software,, then download the windows driver, before install hook up the phantom to the computor and then install the driver,, follow directions on screen, once that is done then you can start the phantom software and it will connect ,, try that, and make sure when you have the phantom powered up and the transmittor on first,, if you plan to upgrade then remove the props,, pretty simple after that. :D
Did all that, then when I connect the phantom, Windows tells me that the USB device is not recognized and shows me an "Unknown Device" with 5 "unused ports". Driving me nuts.
Solved my problem. Killed everything, went back to my download folder, re-installed earlier versions of everything. Don't think the new DJI downloads are quite ready for prime time.
Utica
