No video signal indicator in Litchi
Hi all, I'm using Litchi with a P3S (stock) and a Samsung Galaxy Note 3 (DJI Go not installed). I'm flying short distances ( < 500 ft) in open areas like parks and the drone is functioning properly. I'm even getting good video feed on my screen. The issue is the video signal strength indicator on the screen in Litch. I keep getting zero bars! Nothing is blocking the front section on the RC where the downlink receiver is. I'm getting no red disconnect messages and the telemetry signal strength indicator is maxed out with 4 or 5 bars. There is only the slightest bit of lag in the video, which I assume is normal. Anyone have any ideas what the issue may be?
Which version of Litchi are you using. I had pretty much the same thing happen to me the time before last with Litchi, little or no wifi bars, but everything was still working fine. Now the last time I use Litchi, all was good, with full bars and working good. I did recently update the app, not sure if that was it.
I'm confused. Doesn't 3.9.1 numerically precede 3.10.2 ?
Your right, thought it said 3.1.2, my bad. But what's odd also, don't most companies go to the next whole number once it gets to .9.9, and never use .10 So the next would normally be 4.0 I did check, you up to the most recent version.
Hallo Guys!
I am using the first time LItchi and so far no problems with understanding. I have Litchi installed on a Samsung Tablet Active 2 (Android 9) with no problems. Connection with RC and AC also OK, but the only thing which is missing is the downlink signal bar. Uplink bars OK, batterie Indicator OK. Warming Up procedure OK. Getting the AC in the air,OK, Flying 1200m , move camera, fly up,down,left,right,and pressed return to home, OK. BUT STILL NO downlink bars are shown ????
Can anybody help?
Tried out Version 4.17.0 of Litchi, same result: NO downlink bars. With DJI 3.18.1 App bars are OK.
hcashmore11
