Vision app shows no SD card connected. I can take pictures with app (straight bars slide in from side, not simulated iris display). Pictures get saved on SD card, both raw and jpeg work ok and camera settings can be changed from app. Pictures will also save using shutter button on camera. Can’t take any video because message says no SD card installed. Tried another card (SanDisk 16G class 10) with same results. Tried various camera settings with app and they seemed to work ok, but camera got stuck in 5 sec. infinity interval setting. It appeared to switch back to single shot and other modes but kept taking pictures at 5 second intervals. Was able to clear 5 sec interval pictures by shutting off and rebooting system. App is not getting back information from Vision but it shows image from camera (says no SD card, 0 pictures left, battery 0%, no satellites, no speed, no altitude, no distance, and no compass or clinometer). Camera will tilt with up/down arrows but does not work with gyro tilt control (I see others have this problem with Android app - firmware update coming). When album on Vision is picked it shows no SD card. I can get pictures from card by putting card into computer.
When I pick settings while connected to network or to Phantom Wi-Fi app crashes with message “Unfortunately, DJI VISION has stopped. Report/OK.)
Vision has latest firmware updates from Vision site as of today (11/7/13).
I am using a Samsung Galaxy Note 10.1 model number GT-N8013, Android Version 4.1.2, Kernel Version 3.0.31-813049, se.infra@SEP-63 #1, SMP PREEMPT Wed Sep 25 20:54:30 KST 2013, Build Number JZ054K.N8013UECM13. I have Galaxy mounted on my chest with a GoPro Chesty mount so it is not interfering with antenna.
Problem solved! It was a compatibility problem with Samsung Galaxy Note 10.1 tablet. Solved it by getting an Ipod 5 to use as a monitor for Phantom, everything now works correctly.
