No imagem transmission signal
hi guys
Long time since flying this beautiful toy
Today i tried and everything is working fine, i just do t get the image on my phone, it shows: NO IMAGE TRANSMISSION SIGNAL
its still take pictires and videos, it flights normal, but i dont have the video feed in my screen!
Im not update with everything, just the dji go app.
My versions:
App - 2.8.2
Aircraft - 1.4.10
Remote c - 1.4.30
Ios is still the 9.2.1
Any idea?
Should be the updates?? ios or firmware??
Thanks all !!!
Hopefully this is right
hi
i contact the dji suport and they said to upgrade firmware
i update my iOS and the same problem persisted
im just updating the firware right now, and then the controler firmware
will be back here to tell if everythjing went ok!
THANK YOU ALL!
You may not be able to go all the way to the most recent update. I did a new P3P and it did not want to go to the latest, so I went down to the 1.7 and then to the 1.8 I believe.
Im right now trying to reach the 1.8.80..
the dji support said that i could
lets see
after ill try to update remote controler
hope that this is the problem!!
THANKS so much Prairie
ill be back to say if everything went ok
hi guys
My versions:
App - 2.8.2
Aircraft - 1.4.10
Remote c - 1.4.30
Any idea?
Thanks all !!!
You can't expect latest Go App to be backward compatible with old RC and FC. Usually one keeps on updating all releases together.
There must be a reason why you didn't upgrade FWs to the latest.
