No FLY Zones | DJI
Yes - that map has been up since DJI updated our firmware to create no fly zones. It's a great map for us P2 users since the newer maps applying to the P3s and P4s don't necessarily apply to the P2s.
I use an app called "Hover" which tells you where you can & can't fly. Very useful. If your using a IOS platform, search for it in the apple App Store. Not sure if it's on android but it's worth a search;)
Reactions: dirkclod
Installed it. Looks good but I haven't tested in some of the areas it shows. Needs a bit of work on the legend to show what the different map colors mean.
Just found this useful interactive map from DJI.
No FLY Zones | DJI
That has always existed and it's not very useful. It only lists major airports. I don't see that it even shows Class D airports.
Also, it used to show other NFZ, such as military installations. It no longer shows those either.
IMHO, DJI should either correct that map or remove it completely.
FYI; Beware of DroneBuddy maps. Found a major airport missing and a closed airport shown as active. Best to cross check between apps to be sure.
jorge sanchez
