New user
I have a Phantom 3 Std drone, thanks for the add
Yesterday for the first time I hit a power line and crashed my drone and my gimbal on the cam is acting up. Any suggestions
Reactions: dronesky
First welcome did you do a search for any likewise problems others have had & how is your gimbal acting up the more details pics etc the better help you will get
Reactions: Flying_Doctor
Welcome to the forum! :)
Welcome to the forum! Lots of knowledge to be found here. Upload some pics of the damage so the smart ones can see what's what!
I tried to upload a video and it said attached extension not allowed, it was an mp4
Upload the video to YouTube or Google drive and post the link here. That's how most people do it here. Your video file is probably too large.
Try this, it's super easy and happened to me many times in my Phantom 3 days...
Yes I did check that and its aligned correctly and the set screw was tightened
Hmmm, your right, that probably isn't the problem. Just to be sure it does look like the yaw arm is touching the bottom of the bracket which might be causing your issue. It probably isn't, but it's worth a try. Loosen the grub screw a bit and try to center the yaw arm perfectly between the top and bottom of the mounting bracket. Its free and worth a try, sometimes a crash can shift gimbal parts up and down and even the tiniest shift can cause a world of issues.
I also did adjust that, its slightly off the bottom
Reactions: Weston Ney
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . ?
Does anyone have any other suggestions as to what may be causing the problem that i overlooked
Jerry P
