I purchased my P3S in Oct 2016 and it flew great with an amazing range. I was a former 3DR Solo owner and became impressed with the P3S and made the switch as 3DR was dumping the consumer drone market. After about 3 weeks of great performance from the P3S, it started having cyclical loss of signal.
Indications:
- Upon DJI Go startup, the left side of the screen displays [Latest Firmware] and everything is normal except the “Radio Channel Quality cyclically flashes between “Good” and “Poor” and provides a cyclic warning, “Strong Interference, Fly with caution.”
- When flying over about 60' away, it would cyclically lose connection and begin to return home. I could force the drone to fly further away but would be continually interrupted by the loss of signal and RTH.
Controller: Nexus 7 (2013) (Although I also tried an Asus MeMo 8 with the same results).
Attempts to fix:
-Compass calibrations
-IMU Calibration (inside AND outside)
-Format of the micro SD (4 different times using the DJI Go app and a PC)
-Re-linked the drone and the controller (5+ times using the gimbal wheel/S2 flip method and relinking method inside the DJI Go app)
-Downgrades of the Firmware as follows:
--V1.5.7 - failed. The system provided a message saying it was “not allowed.”
--V1.6.8 - successful but still provided the same bad indications and performance
--V1.7.9 - successful but still provides the same bad indications and performance
-Uninstalled, rebooted tablet, and reinstalled the DJI Go App
Where did the problem occur? In two different geographic locations and settings.
-Rural area in the middle of a farm field.
-In a lightly populated residential area.
That's pretty much what I shared with DJI Support. It went back and forth for a while in a few emails, then they sent me this list of instructions.
===From DJI Support===
“Let us go ahead and attempt to resolve this by following these steps:
To resolve your RC signal issues, please try to follow these steps to fix it.
- Make sure all the firmware is up to date; the latest version for the Phantom 3 Standard is v1.7.90 (This was the latest version at that time)
- Re-link the remote controller to the aircraft.
- The place you choose to fly should be an open and wide area, without high buildings or trees or radio base stations that may cause signal or magnetic interference.
- The antennas on the RC should be adjusted, here is the tutorial link:?
If the problem still persists, please sync your flight records and send us your DJI account used for that flight so we can analyze it. Kindly provide the information below:
* A screenshot of the current firmware on your ABOUT page located in your DJI Go App.
* A screenshot of the error message encountered.
* What mobile device have you used when you encountered this error?
* Video showing the issue"
===End of DJI Support Instructions===
After sending these items in, they provided instructions to send the drone in for repair. They sent me another drone. How do I know? The serial number is different and my FAA registration number is gone. So it cost me $5 for a new registration and some time, but I've got a great drone that flies very well AND, DJI stood behind the product. You just have to be persistent, detailed, and follow their instructions.
I hope this helps someone. The problem loss of signal issue seems to be common.
