New here, questions regarding distance. Trying to understand
I plan on it most definitely. Does anyone know if there is a way to test each antenna? To see if they are functioning peoperly?
While I'm very confident this wire is shot, I just want to check to be sure it is in fact..
Or buy litchi and then let your bird fly by autopilot
Well, the latest update
I ended up getting a cable, and tried to replace it by soldering the new one on the patch antenna. No luck, it flys a bit erratic now so I'm going to assume the soldering job was not done well enough or the cable was not cut to exact length, so it's causing some signal issues.
Ah well,, my DBS will be here Monday so the patch antennas will be useless anyhow. No flying over the weekend is the only shitty part :(
Jerry P
