Drone7 said:LeoS said:IOC home lock mode requires GPS.
It needs to know where the phantom is and where you are exactly, to interpret where the direction to you (home) is.
Let's not start with the assumption that DJI is so stupid to overlook such an obvious solution. They've done a **** good job in packaging a bunch of sophisticated technology in such an easily accessible package that it's easy for people to think this is kid play and a simple product.
Sort of similar to what Apple has done with their phones and computers I guess.
Btw, this behavior is for modes that require GPS, and remember that the phantom has already lost contact with your transmitter. So (auto) changing mode will not help anyway, and trying to fly in a direction that it's not certain to be 'home' may result in flying further away from you.
I wrote homelock first and then i correct myself immediately because i mean courselock.
If you have the possibility´s to try Apm 2.5, then i want to hear you again. No offenseIt doesnt need GPS for courselock and it can still level itself and it doesnt descent just like that when there is no gps signal.
I just want to know if the PV doesnt descent when you loose gps signal and if you can use courselock and atti when you see its descent.
So if you loose gps signal, that means you also lost signal with the tx? That is new for me.
Elginet said:Leo, it was a control loss of signal. I still had video from the fpv. It seems 150 away, or in altitude is when it occurs. I screen captured the phone when it happened. Don't know how to post that here though.
LeoS said:Drone7 said:LeoS said:IOC home lock mode requires GPS.
Whoa, come back to usYou're creating your own scenarios that are confusing yourself (and me)...
If you reread the firmware release log, this new feature\behaviour is triggered when:
a). Control signal is lost. (You can't control it, you can't change its mode)
b). There are less than 6 GPS satellite locks for longer than 20 seconds. (I assume it doesn't know where 'home' is anymore with reasonable certainty).
THEN, it lands.
So your scenario does not involve loss of signal at all, then this behaviour will not be triggered.
That is rather peculiar, since for most Phantom Visions the FPV signal is much shorter ranged than their control signal.
Do you reckon you were near a strong 5.8ghz interference?
Did you lose sight of your PV (5.8ghz relies on LOS much more than 2.4ghz)?
Have you opened your transmitter for firmware upgrade where the antenna connections might be compromised?
Battery readings should not even factor into the flight! its good to send us the info, its good to have a warning, but I don't want the machine to land itself unless it has lost signal.periodLeoS said:Thanks for the heads up!
Seems like it addresses a couple of important issues:
1). Flyaway situation that may be caused by lack of GPS satellites during RTH trigger (either due to interference or loss of tx signal). Rather than going 'home' without a certain GPS lock, it descends.
I fly over water a lot and this would be a death sentence .But sounds like this is only if RTH has been activated and you lose gps so hopefully this combo will not present.
I would think what even if it did a better option would be fly to 60ft and hover for 2 minutes first if no communication is found then land giving us a chance to try and recover it
2). Further improvement on detecting bad battery readings that may cause sudden landing (due to 'invalid battery' error).
gpauk said:Interesting question.
As the number of satellites in view reduces so does the positional accuracy, although it depends where in the sky they are. The HDOP parameter can be used to better qualify this.
But even with reduced accuracy, why not still attempt return to home? If there's any fix at all then it can at least aim in the right direction, and allow the user to take control when closer, using atti mode if necessary.
6 satellites does seem a high value to give up on GPS with.
Nice, but it says this works when in Phantom 2 Vision Mode. Does that mean it's not available if you're in NAZA mode? (In that case, I think you would be toggling S2 between IOC off and HomeLock mode 5 times).iDrone said:...And I especially like the new mark HOME feature: After home is memorized, you can fly/land in a new location and manually mark it as the new HOME by flipping S2 up & down 5-times. Very convenient.
ludorhb said:Just upgraded firmware and did a 10 min flight up to 800ft away and 150ft altitude at night in the cold. No problems.
Firmware Updates on Dec.19
a) In a Failsafe situation, if less than 6 GPS satellites are found for more than 20 seconds, the aircraft will
descend automatically.
Answer: Yes, if it hasn't heard from your TX either - Got pontoons?-T800- said:If less than 6 satellites (more than 20 sec), and you fly over water. Occurs in the water landing??![]()
