The compass will cause these exact flight characteristics, and will not report abnormal readings if the compass orientation has been changed. This often occurs when landing gear has been changed/upgraded.
Yamasung said:Ok, quick recap to answer questions asked.
1. Took quad on vacation (had zero issues prior to this time), did compass dance prior to first flight and everything worked perfectly- tight hover, easy, responsive control, etc.
2. Second flight same thing except at end of flight, landing gear ticked fence, quad lost control briefly and skidded across sand/scrub, but I regained control and returned under stick control only having dropped camera. No apparent big deal.
3. Third time was the near disaster. I did not calibrate the compass prior to third flight, but did get home lock without issue. Upon attempting hover, it was not tight at all and wandered. The wandering wasn't bad and I could control it so I went ahead and flew until the battery switch. After switching battery I performed the compass calibration with no errors, got home lock and hovered again noting the same issue as before, but it seemed worse. This time I tried landing/powering down and once I got it back to the ground is when it powered up on its own and skittered under the cars, etc, etc.
I just got home from vacay so will be checking out the compass values soon. Other suggestions I've heard are: check for loose wires at the flight controller, perform an advanced IMU calibration (have not done this, is it difficult or self explanatory?), check battery terminal connections, ensure compass isn't wet.
All great suggestions and I am thankful for the help guys! That last one got me thinking...when I landed the quad before switching out the battery it was within 3 feet of a pool. Wasn't my first choice, obviously, but I missed the first warning and panicked a bit! It's possible that the compass got wet- I don't think it did, but can't rule it out either.
Will report back with what I find, if anything. Want to get this bird up and flying again without helplessly watching it fly away.
lake_flyer said:Why would the compass be off after changing a battery? There's no reason for that. My own experience make me guess that the quad wrote a new homepoint (and whatever nose position) in midair. Based on odd readings because of a sudden loss of current that homepoint may well be on the other side of the planet. I'm (almost) sure that's what happened in my case.
Yamasung said:Anything important to know before I proceed with this??
Yamasung said:Ok- first bit of data- compass points (raw): X: 52 Y:85 Z:200 Mod:~1160
These appear to be normal based on the software explanation. I will proceed with the advanced IMU calibration anyway.
Yamasung said:...can anyone address my Ground Station question? If not I will post in another thread. Thanks to all for suggestions and helpful comments! This is definitely a fun hobby and I see a gimbals, GoPro and range extenders, etc. in my future...
Yamasung said:dtviewer said:Yamasung said:Anybody know where I can get replacement vibration dampeners for the FC40 camera? Had a minor crash and lost one. Glad they give you extras with the kit, but I'd like to know where to get more if I ever need them and I don't see them listed on DJI's website.
Ebay.
Search Phantom rubber dampers
Thanks!
Yamasung said:"The FC40 is not compatible with the 2.4g Datalink without modification. To make it work, you will need to install an additional PMU v2 to give the Phantom a canbus port." Again, non-electronics guy and still learning what PMU and canbus are, but can someone educate me here? Much thanks...and I realize I am all over the place with topics in this thread. Once the bird is well again, I will start new threads on topic!
