How is it Frank? I'm very skeptical on the ones that say they fit the S, A, 4K and Pro since for the most part the S and the other three aren't the same. I tend to avoid the ones hay say they fit all 4. I'd love to hear if it worked.
Won't be the quality of Polar Pro!For $ 8 I buy CPL or ND4 filter.
Those saying the original falls off are likely not inserting it properly into the slot at the top
My statement about tolerances applies to the OEM holder too!On mine, the tolerances are just off - it's not a tight fit, always had to use tape . . . yet the camera itself fit so tight into the holder I'd say a little prayer before trying to slide it on or off.
As with just about anything mass produced in China, YMMV - I'm sure the OEM solution works fine for many.
I never did find a good way to install and remove the aftermarket devices without stressing the entire gimbal assembly in the process.
I couldn't get the original lens cap off without a struggle.
