NEED HELP ..red led lights and tapping into extra chanel
Hi All,
This is my first post on this forum and I need to know if I can do what I'am
about to explain,....here is my issue. I just bought the Dream-color chasing
RGB led flexible lights, operating voltage is 12 volts-24 volts. I want to solder
the positive wire from the led dream-color chasing leds to the dji phantom 3
main battery compartment. then take the black ground wire and connect it to the
black ground wire on the red led light on the front of the quad, at this point
that should now be able to turn on and off my led chasers from my radio.
BUT ,...I need to know if this is ok to do, without putting an over load on
any part off the board where the red led light for the front of the phantom 3
ties in. hope this makes sense,
hope to here from someone on this issue.
thanks guys,
Kevin M
Hi All,
thanks guys,
Kevin M
You may not get a lot of response on this question, since not many have gone to light modification and adds yet and the overload question is opinion at best. Hope someone can answer this-- good question.
