Naza-M V2 10 percent throllte position?
Avon Indiana
Hi all,
In the Naza manual it states the following:
"Immediately Mode: If you select this mode, in any control mode, once motors start and throttle stick is over 10%, motors will not stop immediately only when throttle stick is back under 10% the motors will stop. In this case, if you push the throttle stick over 10% within 5 seconds after motors stop, motors will re-start, CSC is not needed. If you don’t push throttle stick after motors start in three seconds,
motors will stop automatically."
My question is, where is this 10 percent position? If the center stick position is considered 0, then 10 percent would be a little down from center stick? Is this correct?
Thanks!
10% is from the bottom. The center stick is positioned about half-way through the sweep.
Don carlos
