my current hobbyist $5 license expires 12/12/2023, but no test...?
got my first hobbyist license Jan 2017;
then renewed ?couple? years ago when hobbyist licensing
procedure was expected to change but no test required...
Can I continue without test until 12/12/2023 legally...?
LEGALLY, not morally, ethically, or pontificating how easy the test....
thanks in advance...
Rather than asking here, you could see what the official iine is here:
Note the section in highlighted in bold type.
got my first hobbyist license Jan 2017; then renewed ?couple? years ago when hobbyist licensing procedure was expected to change but no test required... Can I continue without test until 12/12/2023 legally...? LEGALLY, not morally, ethically, or pontificating how easy the test.... thanks in advance... The test is very easy and tests the most basic of knowledge . For me it was mostly common sense with what should be basic flight rules/regulations.
It’s so easy why would you not take it?
You’ve probably already expended more time and effort then you would taking the test.
busywork avoidance syndrome;
or is it sindrone...
but now done & passed:
about B4Ufly app
will be downloading & using first time
any caveats-advice...?
thanks in advance
about B4Ufly app
thanks in advance
Yes! Use Air Control by Aloft.ai. It is the app that B4UFLY defers to when you need to apply for LAANC clearance should the need arise.
They both show the same airspace information, but if you use B4UFLY you will also need to install another app to apply for LAANC clearance if needed.
muskansahu
