Mounting Hub, AVL, iOSD?
After purchasing the Hub, decided not to use it. Instead, I spliced the wires and mounted everything (except AVL58) inside the body using 3M.
Thanks, I have a bunch of different tapes at work I can use. I definitely want to use the hub, in fact I got two kits. I want to be able to easily remove everything back down to the bare P2 if needed
