Motor
The P4 motors, do they have a stable sensor as one motor loose after slight crash? The upper shell holds the motors by plastic clips, so the motors just clip on? Just wondering if not will get error either red or whatever? See pic
But then again bottom shell to top shell motors are screwed?
So am I ?
Each motor is secured to the shell with three screws. Two of the three screw holes are clearly visible in your picture.
Yep we got that bit but, is the chip on top of the motor a sensor which talks to SW to say “We are in correct position to take off”?
What are you referring to?
There is no such sensor.
Reactions: PhantomFandom
[/QUO
the chip in the middle has 3 wires connected the others for motor?
That is the under-arm LED.
You manage the forum and reply to my post?
It’s secured by 3 screws Fliper, well buggar me an u got pic of lower&upper case separate? How did I miss that?
Your forum is load of maybes not defo?
I have No association with site/forum ownership or management.
It is difficult to fully understand your way of writing.
I’m only trying to help you despite this communication ‘gap’.
The ‘chip’ is an LED, defo!
Easy done
Just look at my forum requests for last two months on Andy999xxxz?
Read that then you no were I’m at?
Pauos31
