got the Mobius cam working on the gimbal today , very easy mod. made a CF brace 10 mm x 50 mm. drilled a hold for the screw to hold camera to the camera mount. took the 4 pins off the original mount, so the back part of the camera cage is now were the Mobius sits. the CF brace is on the back of that. a the screw pulls the camera against it . I used a bit of LYNX double sided tape, for vibes,, just had to push the gimbal set button , to point camera to were I wanted it, a few tries, and got it to work great... just spent $700. on a ipad air to use with the fc40 cam. so I mounted that on battery door, my flight times still suck. tried 2 x pulse 2700 MAH, have to keep stick above mid to hover. so I guess I need to play with gains.. I could use some help on this, if someone can post some gains #. would be great. mine a what ever the up to date gains are.
