Missing mp4 file when i transfer to computer
When i record video and pictures i am missing some of the video fils.
When i look on all fils there are number 1,2,3 missing one and then 5,6 and so on.
Somehow the file is deleted ?
If i tray to recover i can find the missing file but if i restore it is just black screen.
It seams that is only big fils about 10 min recording.
What happen what du i do rung. ?
It's probably a corrupt video file because you switched off the aircraft before you stopped the recording with the app and the file couldn't finalize. Put the SD card back in the Vision, switch it on and leave it for 30 seconds, switch it off and check the card again. It will have finalized the corrupt files but will have lost the last several seconds. It will also give the file a date stamp showing 1st Jan 2008...
It don't work after, but if i wait longer a minute ore so before i turn off the phantom i don't see the problem.
Thanks for your advice. :)
