mini iosd help
Hi I have a phantom 1 and want to add fpv from a iPad what do I need to get.there seems to be lots of things out there.is it as simple as buying the mini iosd or do I need the ground station as well I took the case off and I have the naza m v2 .what are other people using .
Thanks ian
IAN, as far as I know it isn't available yet to use an Ipad for FPV. The typical FPV system uses 5.8mghz whereas your Ipad is 2.6mghz. You can add the ground station and control the flight via your Ipad and see it real time (like a google map) but it won't show camera view. The Iosd mini just puts stats overlay on camera view. Others may chime in but I don't believe it's available (yet)
