Maximum Take Off Weight (MTOW) Phantom 4 Pro
Not sure that spec is published anywhere. The unit isn't designed for a payload and additional weight beyond stock would probably alter flight characteristics (as well as reduce battery life even further) so you would essentially be a test pilot.
There are other models that are designed for carrying loads, one of those would probably be a better choice if that is your goal.
I'm filling a form and it needs the Kv of motors and the MTOW. Anyway thanks for your kind answer.
Ah, I see. In that case I'd just use the actual weight of the vehicle with battery. Since it isn't designed to carry a load then the MTOW and static weight would be the same, or at least close enough to fill out a form.
I found a spec for a replacement DJI Phantom 3 motor which is 960 rpm/V. That's probably close enough to the P4, if not identical.
wkflysaphan4
