Master Airscrew props
No, only Maveric from what I see and yet there are for more P3's around I would think!
I ordered mine direct from MAS. They came quickly considering we’re in the midst of a pandemic.
Reactions: Rickster565
I started using these a couple of months ago on my P4P and M2P. I notice a big difference on the M2P with noise and flight smoothness. Not so much on the P4P. I ordered two more sets for the M2P since I’ve begun to use it more for quick jobs.
My props arrived, very quickly actually, considering they came from the US.
The threaded 'nut' is not an integral part of the prop but is secured in place and can be moved slightly. Difficult to tell if its metal or plastic without scratching the surface, which I don't intend to do.
The edge of each blade tip is curved upwards slightly.
So far I've only done a hover check of the new props in my back garden and can't say I noticed they were any quieter than the oem dji's.
It is very difficult to quieten propellers as most of the noise is generated by the tip velocity and no matter what prop you install of the same length and pitch, this doesn't change.
