Are there any video tutorials on youtube about manual flying?
I try to learn it but it has a very steep learning curve!!
Last week I crashed with an amazing high speed. Luckely almost no damage.
I learned several things now. The most important switch is S1. If you lose control switch immediately back to GPS mode.
The second most control is the trottle. If the bird is going to fast and diving to steep push it all the way up and with a little bit of luck you will regain control. If not..S1
The phantom is in the manual mode inherently unstable. Also vertically. That means you have to work actively with the controls all the time. As soon as you switch to manually its starts to decent very quickly and you have to push the trotlle up to get it hovering. If you going for/backwards or sidewards it always dives to a high speed if you not counteract this with the upward trottle.
Needless to say that you should start on a high altitude, at least 30 to 40 meters.
Its quite amazing and gives a lot of fun. But my steps have to be very small as I don't no yet what the flight dynamics are in manual mode.
Advice and tips please.
Ton
Ton
