Man Accused of Flying Drone Above Anti-Trump Protest - Oh boy. This is all over my local news.
The FAA’s Thoughts on Night Operations
The FAA gave us very insightful comments on pages 42,102-103 of the Operation and Certification of Small
Unmanned Aircraft Systems that was published in the Federal Register.
Nighttime operations pose a higher safety risk because the reduced visibility makes it more difficult for the person maintaining visual line of sight to see the location of other aircraft. While the existence of other lighted manned aircraft may be apparent due to their lighting, the distance and movement of small unmanned aircraft relative to the distance and movement of those aircraft is often difficult to judge due to the relative size of the aircraft. In addition, visual autokinesis (the apparent movement of a lighted object) may occur when the person maintaining visual line of sight stares at a single light source for several seconds on a dark night. For this reason, darkness makes it more difficult for that person to perceive reference points that could be used to help understand the position and movement of the lighted manned aircraft, the small unmanned aircraft, or other lighted object.
The lack of reference points at night is problematic for small UAS subject to part 107 because they are not required to have any equipage that would help identify the precise location of the small unmanned aircraft. As such, a remote pilot in command operating under this rule will generally rely on unaided human vision to learn details about the position, attitude, airspeed, and heading of the unmanned aircraft. This ability may become impaired at night due to a lack of reference points because all a remote pilot may see of his or her aircraft (if it is lighted) is a point of light moving somewhere in the air. For example, a lighted small unmanned aircraft flying at night may appear to be close by, but due to a lack of reference points, that aircraft may actually be significantly farther away than the remote pilot perceives. An impairment to the remote pilot’s ability to know the precise position, attitude, and altitude of the small unmanned aircraft would significantly increase the risk that the small unmanned aircraft will collide with another aircraft.
In addition to avoiding collision with other aircraft, remote pilots in command must also avoid collision with people on the ground, as well as collision with ground-based structures and obstacles. This is a particular concern for small UAS because they operate at low altitudes. When operating at night, a remote pilot may have difficulty avoiding collision with people or obstacles on the ground which may not be lighted and as a result, may not be visible to the pilot or the visual observer. As such, this rule will not allow small UAS subject to part 107 to operate at night (outside of civil twilight) without a waiver. . .
Civil twilight is a period of time that, with the exception of Alaska, generally takes place 30 minutes before official sunrise and 30 minutes after official sunset. The FAA agrees with commenters that operations during civil twilight could be conducted safely under part 107 with additional risk mitigation because the illumination provided during civil twilight is sufficient for terrestrial objects to be clearly distinguished during clear weather conditions. As a result, many of the safety concerns associated with nighttime operations are mitigated by the lighting that is present during civil twilight. That is why current section 333 exemptions permit twilight UAS operations. Accordingly, this rule will allow a small UAS to be operated during civil twilight.
However, while civil twilight provides more illumination than nighttime, the level of illumination that is provided during civil twilight is less than the illumination provided between sunrise and sunset. To minimize the increased risk of collision associated with reduced lighting and visibility during twilight operations, this rule will require small unmanned aircraft operated during civil twilight to be equipped with anti-collision lights that are visible for at least 3 statute miles.
A remote pilot in command may reduce the intensity of the anti-collision lights if, because of operating conditions, it would be in the interest of safety to do so. For example, the remote pilot in command may reduce the intensity of anti-collision lights to minimize the effects of loss of night vision adaptation. The FAA emphasizes that anti-collision lighting will be required under this rule only for civil twilight operations; a small unmanned aircraft that is flown between sunrise and sunset need not be equipped with anti-collision lights.
The FAA acknowledges that current exemptions issued under Public Law 112–95, section 333 allow civil twilight operations without a requirement for anti-collision lighting. However, the section 333 exemptions do not exempt small UAS operations from complying with § 91.209(a), which requires lighted position lights when an aircraft is operated during a period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon). As such, UAS currently operating under a section 333 exemption have lighting requirements when operating during civil twilight.
However, while current section 333 exemptions rely on position lighting, it would be impractical for this rule to prescribe specifications for position lighting for civil twilight operations because a wider range of small unmanned aircraft will likely operate under part 107. Position lighting may not be appropriate for some of these aircraft. Thus, instead of position lighting, small unmanned aircraft operating under part 107 will be required to have anti-collision lights when operating during civil twilight. The FAA also notes that meteorological conditions, such as haze, may sometimes reduce visibility during civil twilight operations. Accordingly, the FAA emphasizes that, as discussed in the following section of this preamble, this rule also requires that the minimum flight visibility, as observed from the location of the ground control station, must be no less than 3 statute miles.”
You need to read the included FAA comments in the article, not just the Cliff's Notes. The included text of the FAA comments are very insightful. Please read them first, before passing judgment. The whole point is that, from the air, you cannot gauge distance from a light, or even if the light is in the air, if you are seeing it from above.
Nothing is going to change my mind, you should know this by now. I and nothing is going to change yours. I'm over this lol. I think there should be a light and you don't. We are just going around in circles.
We are helping educate the unwashed masses who fly illegally at night! :cool:
So you can fly a helicopter around the city but not a drone lol ......to funny...I know what would cause more fatalities if **** went down
A sad event indeed. Multiple issues with this. Flying at 1,500 feet? Flying in restricted airspace? It is this kind of stupidity that makes it hard for everyone. This young man deserves whatever is provisioned to him.
Yes. For recreational flyers, it's called Part 101 which every drone-flying hobbyist in the US should be intimately familiar with.
Click on the link below and scroll down to the very bottom and read (d).
eCFR — Code of Federal Regulations
If he interfered with the police helicopter, then he's in violation which means he's not flying under Part 101 which leaves him wide open to all sorts of hurt.
But even without the police helicopter, there's also (b) which indirectly yet absolutely refers to AMA's safety code which states:
You must avoid flying directly over unprotected people, vessels, vehicles or structures.
So that's another violation.
Isn't it part 107 that covers drone regulations, registering and pilot information?
Reactions: BigAl07
I looked at part 101 an it's for balloons. I think it's part 107 that covers drone regulations, registering and licensing.
It will be interesting to follow the outcome. IMHO, the guy is screwed (and maybe should be). Going to cost him seriou coin! As an aside, what 3rd grader wrote that article? Some really curious wording in it.
lol it was like a 3rd grader, im only like a 7th grader and it was still terrible
It's like it's been done using Google translate and nobody proofed it before it went out.
eg "..one of many pilots who was within the helicopter.."
Many pilots?
Whoever wrote the article did indeed do a horrible job. The student flying the drone is guilty of breaking a couple FAA regulations and for that, should pay a fine. I don't think any jail time is warranted, but I'm sure he will be fined. And to be honest, I cannot feel sorry for someone who blatantly disregards rules and regulations AND the safety of others for his own agenda.
Reactions: Jnnyr
The text is machine transcribed.
