Mad dance of a bad gimbal. enjoy.
verisimilitude said:
dmm said:
All updates and calibrations performed.
https://www.youtube.com/watch?v=8T_WRIvMk84
the pitch or tilt axis is the problem, so battery clearance is not the issue.
...and another guy that didn't install the gimbal properly.
Hey that's my video how do you think it is installed improper???
It worked fine for 4 flights and then malfunctioned in mid flight.
https://www.youtube.com/watch?v=BcVUW1JE5Fg
P.s they won't give RMA numbers online anymore. I guess they are flooded with problems. Didn't even pick up phones today!!!
Already installed v1.1 gimbal and it seems fine so far.
Hope I didn't install it improperly too :P
I saw your issue with your gimbal... Recently I had a similar issue and was able to fix it by tightening a loose screw inside on the right side on bottom with small hex screwdriver
So I had the same thing happening, started mid flight and eventually cause the Phantom to crash...I looked around, found a broken ribbon cable and replaced it but that didn't work. Advanced IMU calibration did nothing either. I guess I'll have to send the gimbal back!
