Low Battery made
I had a deal last night where the battery got lower than i thought and it went in to auto land... The problem was it landed in a fescue field . When i found it the grass stems had wraped around 2 of the props and they were still tryin to spin but could'nt so the motors were really hot... I cleaned and cooled them and they started working , but they seemed to get hotter that the other 2 motors is there anything i should do . or just fly it till it drops from the sky ????
Do you get any motor obstruction prompt on start up,,do they still feel ok to turn,,if anything the esc would have cooked if left so you might have got it just in time not to have caused a issue,,could do imu check ,if it's out it will say calibrate,,,next flight put it through some hard turns etc to make sure things still working before any flights at height,,?
