losing conection
hi all, have been losing connection and sometimes cannot conect with p3 professional?
sometimes i cant even connect sitting in the same room then othe times it connects and then loses signal within 100m in full view and then automatically flys home and wont connect again ?
any help would be appreciated?
Are you pointing the flat sides of each antenna at the aircraft at all times?
rebind did not work, not sure whats going on it ussually connects fine, i have swapped tablets a few times but they usuualy connect if ive got wifi, but now both of them struggle to connect even right next to the phantom 3? its frustrating :(
I'm having the same problem also. All firmware is up to date. It connects better in my garage then when in the street. But, at the same time, when I go to the field across the street, it seems to connect just fine! Any suggestions?
ODIN Reviews
