ive seen some longer legs on eBay for the P3, but can't work out how to get the wire covers off the original legs, anyone done this mod ?
Not sure what wire covers you are referring to, probably the antennas. They just pop out with a flat head screwdriver with a little bit of prying. You will also need to remove the two small screws covering the compass module and cut it out of the glue. The legs have two screws each and then the antennas will slide through the openings.
Robert
I bought these from Polarpro for $30. Ebay is the way to go!You might also try the black chinese landing gear extending / stance widening gear for $7.00 on Ebay. No potentially wire- severing surgery required. Snap on and off.
