- Joined
- Jan 19, 2017
- Messages
- 94
- Reaction score
- 12
- Age
- 28
Wow. Think a lot of guys would love to know how you got litchi to do a one way flight as it won't let you as waypoints are to far. Nice distance mate. Haven't done that far at all. But have done an 18 mins flight so I know how scary it is lol. Was it mission based or a one way Manuel flight? If so how did you keep signal?Anyone ever made a flight this far with phantom 3 se?
nope I cant even go past 3500 feet even in an open field what is the secret to getting at least 2.5 miles like promoted.Anyone ever made a flight this far with phantom 3 se?
how did you get 22K with out any modification to your controller that is what I want to do I don't want to add all that bulky hardware to mine.Was that an autonomous flight or did you maintain control and video throughout & whats your controller setup ?
My max is 22,160 feet Outbound and same distance return using the Standard/SE controller
how much did your whole system cost and how hard to install itView attachment 101260
Its just not possible to get 20,000 in a fully controlled flight without modification of that controller. Playing with reflectors is like placing your faith in witchcraft. I've tried every recommendation from reflector, to argtek to itelite dbs - the argtek is useless and the itelite overpriced producing a very narrow width signal.
The default external 5.8ghz omni antenna used for control with its low signal strength is just not up to the job and the two internal 2.4ghz panel antenna are also fairly feeble. The internal cables linking to these antenna are low quality and prone to attenuation of signal.
To get any real distance, You need greater signal strength and a focused signal which a good low cost panel antenna like the Alfa will provide.
Before modifications, all I could get was about 500 yards in flat country with trees - CE Europe. In my case, all modifications can be removed and reverted to default. I could make the controller more compact however i didnt want to drill the housing, hence the Argtek bracket.
My device also has a payload dropper fitted - triggers when i turn on the red lights - great little device
