- Joined
- Aug 7, 2015
- Messages
- 3
- Reaction score
- 1
- Age
- 56
On my p3p i often get kompass error wen i fly in sirkles anybothy expiriens With Thatcher??
I used my wifi to stream to youtube with 0 video issues.. just disable the 2.4 and conect to the 5.8 and you will be good....
The P3 only uses 2.4Ghz for video and control.... No such a thing as 5.8Ghz on the P3. except for the standard.What about the 5.8Ghz used by your TX. Doers it not limit the range of your TX if you also use the 5.8Ghz in Wifi ???
Marnix
Thanks for pointing me in the right direction, but here is my problem/concern. I live way out in the country and do not have cell phone reception at all. Am I correct in assuming that you must have Cell Phone Reception in order to Live Stream? Here is an example of what I could potentially be facing. Let's say I get a phone call to show up and assist the county Sheriff's Department to do a fly over some property for whatever reason. They want to see what is going on down below but the property is way out in the middle of nowhere with no cell phone reception. Now they have asked that I Live Stream the fly over so that several law enforcement persons can all see the fly over at the same time and in real time. What can I do to accomplish this?Live streaming instructions found here:
Hello there,You got it. Love the shield! But like somebody else here figured out you can't connect any tablet to WiFi to stream because it screw's up the lightbridge feed. You MUST have a tablet with 4g LTE or you are SOL. So everybody with non LTE tablets are screwed.
Hello there,Well you have some issues to overcome to get this to work
1. You will need to have your streaming device connected to the Internet at speeds fast enough to keep up with a live feed.
a. You are in a remote area that may or may not have cell service
b. If so is the connection fast enough to transmit said feed live
c. If not, then in an emergency situation you will need to locate a nearby residence within the p3's range of the property to fly over and obtain permission to access the Internet and connect your streaming device. May not be possible.
In conclusion, to stream the feed live you obviously need to be connected to the Internet in some way to send the data. There is no other option short of having a military grade drone capable of satellite direct connection . They may just have to settle for a non live feed. In other words fly over the property, return quickly, and upload said footage to YouTube or designated server via a computer already connected. The only other option is for you to install the new hdmi out board, them to be near you during flight, and display the video in a command center to a tv so they can see it. Perhaps someone else can chime in.
Hello there,Thanks for pointing me in the right direction, but here is my problem/concern. I live way out in the country and do not have cell phone reception at all. Am I correct in assuming that you must have Cell Phone Reception in order to Live Stream? Here is an example of what I could potentially be facing. Let's say I get a phone call to show up and assist the county Sheriff's Department to do a fly over some property for whatever reason. They want to see what is going on down below but the property is way out in the middle of nowhere with no cell phone reception. Now they have asked that I Live Stream the fly over so that several law enforcement persons can all see the fly over at the same time and in real time. What can I do to accomplish this?
Thanks ever so much for your help.
Hello there,Can someone tell me where the step by step instructions are for live streaming from P3 Professional, and do you need to purchase anything additional? The DJI GO app just came out (looks like it upgraded automatically to my iOS devices) and it mentions live streaming as well.
