For a waypoint mission in Litchi, the info is stored in the Phantom AFTER it’s uploaded to the bird (i.e., after you hit “start mission”).
Also note the Phantom will complete the mission even with loss of signal,so you cannot cancel mission or initiate RTH with loss of signal, which may be an advantage or a disadvantage. Autopilot app allows you to select what happens with loss of signal.
You have no choice, upon loss of signal you cannot cancel the mission, or start RTH, the Phantom will attempt to complete the mission until it comes in signal range again, and then you can cancel.So with Litchi if you know that you have enough alt. and batt. to do mission then upon loss of signal always best course of action is let the mission finish.
