Preview Quality
(Displayed only when Litchi is connected to your aircraft) Choose 4, 6,
8, or 10 Mbps (megabits per second). The quality of the preview video displayed on your
iOS mobile device during flight can be controlled here. High numbers provide clearer
video but also put increased demand on your device’s microprocessor (and, if selected,
your graphics processor). If you suffer faltering video, try a lower Preview Quality rate.
Anti-Flicker
Choose Auto, 60Hz, or 50Hz. An unpleasant “flicker” effect can sometimes appear along
horizontal lines when you are shooting interlaced video. An anti-flicker filter set to the
power line frequency used in your country (generally 50Hz or 60Hz) can reduce the
effect. Select either Auto or the power line frequency in the area where you will be
shooting.
Mobile Device GPS Accuracy: The estimated accuracy of your mobile device's location, in meters/feet. If you draw a circle centered at your mobile device's location, and with a radius equal to the accuracy, then there is a 68% probability that the true mobile device's location is inside the circle. If this number is red, it means your current location accuracy is over the minimum location accuracy general setting. In such a case, you will not be allowed to start Follow. If you are having difficulties getting a good location accuracy, try another area, try another mobile device, or increase the "Location Accuracy" general setting. Setting the "Location Accuracy" to a higher value will allow for a bigger margin of error for the mobile device GPS signal, but the follow me movements may be less precise.
