Litchi Mission Switch to ATTI mode mid mission - P3P
OMG, now we get the full story. :)
"Calibration measures the magnetic fingerprint of the surrounding area and on your drone itself."
Posted in this thread.
I really appreciate you posting your findings, so few do.
A lot of us try hard to help others, when it gets figured out we all learn.
Rod
Thanks Rod, and everyone else that helped. How dumb can I get. I (use too )know better. Thanks for the compass primer link. It is a very good refresher.
Reactions: RodPad
Until I hung around here long enough, I did the compass dance anytime I flew in a different area. I was stuck on deviation concept I guess.
I had never thought the calibration of compass was for the Phantom's own structure.
Rod
FYI:
Maybe I have found the reason why those two Litchi missions, at the fly-in-get-together, failed in ATTI mode! The night before the fly-in, Charlie said to bring my fishing bomb drop attachment. So I bolted on my Gannet fishing bomb drop. It contains some electronics and a battery! (see link below) I simply bolted it on and went flying. Those first two missions failed in ATTI mode.
Now when I first got this device a year or more ago, I bolted it on, and I am sure I calibrated the compass and the IMU and the control sticks. Then went and did a number of tests. After many tests with the bomb drop device, I gained confidence that it did not affect anything. I flew with it for many flights for over a year. No problems. Then I took it off for the Winter, because Joyce was not going fishing this Winter. I am sure I calibrated the IMU and compass again several times during the long time it was off the AC. Now for this fly-in I simple bolted it back on and thought nothing about it. I had the two ATTI failures at the fly-in, and many more ATTI failures during the testing described above in this thread. Until I calibrated the IMU and compass with the unit back on the aircraft. Then the ATTI mode failures stoped!
Could this explain my problem and why it has been solved? In my mind it could be the culprit. Finally explained, and understood.
As always, constructive commence welcome.
See:
Thanks for the heads up. I use the gannet sport manual release. Going to try their new xsport model with electronic/manual combo release. Will watch for this problem, and if necessary, use your solution. Thanks
Reactions: RodPad
Capt KO, don't wait for the ATTI mode to happen when you are not expecting it. Just calibrate your compass (and the IMU) when you install your device on your AC.
And calibrate again whe you take the device off of your AC.
Joe
KC7GHT
Reactions: Capt KO
Jade Dawson
