Litchi mission recording max out at 9:06?
Whenever i fly a mission over 9mins6sec recording stops & starts a new recording always & go to anthr 9min6sec. Is there a setting that would prevent this from happening?
Hi, the max filesize on your SD card is 4,2 GB, try setting the recorded resolution lower and you will get more minutes per file.
Cheers!
Yep, is that the size of files 4 gig? Nope no fix, some say you combine the two, others say you combine the two and there is some frames missing.
Rod
rockymountaincaptures
