I just purchased the Litchi app and wanted to know if there were any tips on how to use it? Any things I should know or be aware of? Also, how do you do the little planet pics with this app? Thanks
Have been using Litchi for about a month now with terrific results. Here's a few things I've learned.
1 On a Litchi flight plan the drone will often be flying sideways. The obstacle avoidance only works for obstacles facing the 'front' of the drone - for many Litchi flights you will have no obstacle avoidance
2 This makes it very important you 'eyeball' the flight path and not depend on the satellite imagery provided by Litchi
3 If the drone becomes disconnected because of poor signal strength it will complete the flight
4 Practice small flight paths first, by small I mean you retain visual contact with the drone
5 Give yourself plenty of vertical room - if you're not sure of the height of an object (building, tree, bridge) fly to it manually, check the height and add 10m
6 Make sure you understand the difference between elevation and altitude and how to fly over terrain which varies in elevation
7 Double check your RTH altitude in relation to the terrain you're flying in
This is a link to my first Litchi flight. I love the app but have had a couple of near misses because all due to pilot error
