lipo battery question.
Discussion in 'General Discussion' started by Monte55, Feb 1, 2015.
  1. Monte55
    Raymore Missouri
    I have the Phantom 1 using stock 3s 2200 ma batteries. Since this question is for all the lipos, I put the question here. I have a cell checker that shows voltage of each cell and also percentage of power left for each cell. Fully charged the percentage on a 3cell may read 98 95 97 %. Ok so I go out and fly till I get the first battery warning. I recheck the battery. It may read 14 32 28 %. I don't get that. It's like the cells don't discharge at the same rate. Is this normal. New or older battery does the same. I don't understand the large difference between cells. Flying times are normal it seems.
  2. Monte55
    Raymore Missouri
    Nobody have a clue?
  3. Old Gazer
    Eastern Oklahoma
    I don't use these batteries, so I don't know just how they work. It sounds to me like they need to be balanced. I believe it takes a balancer in line with the charger in order to work. I would think someone with more knowledge than I could chime in here
  4. kitari
    Paris, TN
    Found this on another forum.
    Voltage and Cell Count:
    LiPolys act differently than NiCad or NiMH batteries do when charging and discharging. Lithium batteries are fully charged when each cell has a voltage of 4.2 volts. They are fully discharged when each cell has a voltage of 3.0 volts. It is important not to exceed both the high voltage of 4.2 volts and the low voltage of 3.0 volts. Exceeding these limits can harm the battery.
    The way to ensure that you do not go below 3.0 volts while flying is to set the low voltage cutoff (LVC) of your electronic speed control (ESC). It important to use a programmable ESC since the correct voltage cutoff is critical to the life of your batteries. Use the ESC's programming mode to set the LVC to 3.0 volts per cell with a hard cutoff, or 3.3 volts per cell with a soft cutoff. If your ESC does not have hard or soft cutoff, use 3.0 volts per cell. You will know when flying that it is time to land when you experience a sudden drop in power caused by the LVC.
    If your ESC has an automatic lithium mode. Use it, it will correctly sense the number of cells and set the auto cutoff appropriately.
    If you have previously been flying with NiCad or NiMH batteries, switching over to lithium polymer will result in a different number of cells being used. If you had 6 to 7 round cells then 2 lithium polymer cells will correctly duplicate the voltage of those cells. If you had 10-11 cells then 3 lithium polymer cells would be right for you. There are a lot of 8 cell flyer's out there that are stuck between 2 and 3 cells. In my experience the best option is to determine how many watts you were using before and duplicate that with your LiPos, Motor, and Prop. For example. If you were running 8 cells (9.6volts) at 10 amps on a speed 400 airplane, then you have 9.6 x10, 96 watts. So if you went with 2 lithium polymer cells (7.2 volts nominal) then you'd need to change your prop such that you used 13 amps. If you went to 3 LiPoly's (10.8 volts nominal) then you'd need to reduce the amperage to 8.9 amps. These estimates are approximate, and some experimentation is required for best results but conserving Watts is a good way to start
    Here's the link to the full guide, maybe it'll give you some answers. http://www.rcgroups.com/forums/showthread.php?t=209187
Similar Threads - lipo battery question Forum Date
???Question About Phantom 3 LiPo Battery Balance Charging/Discharging??? Standard/4k Discussion Feb 8, 2017
RC Battery Question (LiPo Pro/Adv Discussion Nov 21, 2015
LiPo Battery question for a real LiPo battery Guru General Discussion Sep 14, 2015
Lipo Battery Voltage Tester / Low Voltage Alarm Question General Discussion Mar 11, 2014
Lipo Battery In Controller Pro/Adv Discussion Jun 26, 2017
