Lead Battery Charge with Hitec X4
Here is the setup.
Hitec X4 battery charge, which by the way I really love.
I have a lead acid battery 12 volts, 4.0 AH
What should I set up the X4 charger settings for this battery.
The battery label says 13.5 to 13.8 Volts standby
Cycle use 14.4-15 Volts
Initial current less than 1.2 Amps
So how do I charge this baby.
Theory says that .4 of an amp will be the optimum. If your charger won't go that low 1 amp will be fine. Being an SLA battery 14.4 is fully changed and the charger should go to float mode. After taking it off the charge it will probably stabilize around the 13.8 volt mark.
I can also set a cut off or maximum reached, so ill set if for the 13 and the bit you suggested
Thank for the info
