Laser engraver
Edmonton Alberta
Here's an interesting tool. ;-)
NEJE JZ-5 500mW High Speed USB DIY Mini Laser Engraver $82.11
This mini laser engraving machine operates with high precision and stability and is great for DIY engraving. The Neje JZ-5 laser engraver is ideal for engraving into materials such as hardwoods, plastic, bamboo, rubber, leather, paper card and so on. However it is not suitable for engraving metal, aluminum or acrylic.
The unit has a strong, sturdy structure, its unique frame is manufactured from rigid components for maximum stability. It utilises a 500mW high speed blue laser head for the ultimate in precision high speed, high resolution engraving and this also increases the variety of materials it can engrave, it is that precise that you could even engrave a toothpick!! The laser engraver supports automatic positioning and has an adjustable focus lens to manually adjust the "laser dot" for different widths.
The printing area is 38mm x 38mm and you can print images with 512 x 512 pixel resolution and is supported by Windows XP, 7, 8 and 10.
Yes the print area is small and no it can't do materials like aluminium or steel, so you won't be starting up an engraving business with this, but if you want an inexpensive, fun little tool to introduce you to laser engraving before you become Auric Goldfinger, then this Mini Laser Engraver is perfect.
Important Note: Protective laser glasses are supplied with the engraver, these must be worn at all times when operating the machine.
Features:
• Strong and sturdy structure
• High speed and high resolution engraving
• High precision, will even engrave a toothpick!!
• Will work offline
• Support Win XP, Win 7, Win 8, Win 10
• English professional design software
• 500mW high speed blue laser
• Automatic positioning
• Manually adjustable focus lens
• Will engrave hardwoods, plastic, bamboo, rubber, leather, paper card etc
• Printing area 38mm x 38mm
Specs:
Support Software: Laser_Carver
Image Formats: jpg
Image Size: 512 x 512 pixels
Image Engraving Pattern: Bitmap engraving
Power Input: Dual USB
Input Voltage: 4.2~5.5V
Input Current: 1A
Laser Power: 500mW
Support: Win XP, 7, 8 and 10
Dimensions: 18 x 13.5 x 13cm
Weight: 970g
Color: Black
Includes:
1 x NEJE JZ-5 Engraver
1 x Laser protective glasses
1 x Allen wrench
2 x USB cables
1 x 1Gb TF card
1 x User manual and installation software
1 x 5v 1A power plug adapter
Software download link: www.trusfer.com
THIS IS A LASER, IT WILL BURN OUT YOUR RETINAS IF USED INCORRECTLY. PLEASE ENSURE THAT YOU TAKE ADEQUATE MEASURES TO PROTECT YOURSELF AND THOSE AROUND YOU WHEN USING THIS TOOL AND ALWAYS WEAR PROPER EYE PROTECTION.
RedHotPoker
Reactions: BigAl07
Lucas_rc_pilot
