Landing Precision - Helipad
Got a Phantom 3 Pro. Did the calibration. Took off using the "lift off" button. After flying for couple minutes tried to land using the H option.
It does not come back to the spot it took off from. Its off by at least 6 to 8 feet.
Anyone else seen this?
Yes thats quite normal, my P3 has never landed exactly on the same spot. Its usually off by a meter or two.
The P4 is capable of precision landing by taking a picture of the takeoff location. Otherwise it's often off by a few feet.
That bugged me at the start too. Now, if the landing point or descent is critical I alway do it manually. From where I take off in the garden the wander is enough for it to go into trees etc.
Reactions: 3rdof5 and Pursuer
I find that autolanding lands abit too fast with an abrupt touchdown and bounce which has always concerned me with the camera and gimbal. I always land manually now to both land exactly where I want and as softly as I want. And if i cant land someplace safe and level or if it suddenly gets windy I'll just hand catch it to be safe.
Ditto on all scores.
Would it be possible to autoland P4P on a square 1m plate laying on the water?
Would you do that?
My P4P would normally do that, providing you did a "precision" takeoff.
Also, providing that your floating 1 meter square doesn't drift somewhere in the water, which seems pretty likely. Even calm water is seldom motionless.
Would you do that?
You can try, but it probably won't work.
Water has no constant features for precision landing to recognise.
That's quite normal because that's within the expected accuracy for consumer GPS.
Sometimes it will be a bit closer, but it could even be a little further away.
It's good practice to pick a launch spot clear of nearby obstacles to allow for this.
If you want pinpoint RTH landing precision, you need a P4 or later, as they have a precision landing feature using optical technology.
Don carlos
