Landing Gear
I accidentally ordered the landing gear for the PV2 for my PV2+. I know this landing gear is a little shorter. Is there any reason why I can't use this?
Edit: D-Bird set me straight. Thanks ;)
Kelvinator said:
Will the shorter gear be ok to use though?
I'm not 100% sure as I don't have a standard Vision set to compare? You would have to ask someone with a Vision to measure the height of their gear, compare it to that of your V+, and then measure how much clearance you have between the cam & the ground.
most
