Landing gear retracts for p3s
Yes, but you have to install the gimbal garage mod first. That way when you retract the gear, the antenna can go to the garage roof.
tobby
Not unless you make it DIY project which generally isn't cheap, ime.
Another question is "Why?" since the P3 camera doesn't rotate enough to make the landing gear an issue and why those drones need the gear out of the way.
Probably cheaper to buy one that does it already (e.g. Yuneec, or save for an Inspire or Matrice.) as you need the on board electronics, as well as maybe some extra thrust to lift the added electrics/electronics too.
You would also need another channel for signaling the gear to retract or deploy.
As for why you would want it, I totally get it. Props in field of view are bad enough. I hate getting the skids in there, too.
tpren3
