Just bought a Phantom 3 4k. Need advice
Minnesota
My drone will be arriving tomorrow, July 1st. I have a Syma X5C which got me to love drones, and I'm fairly good at flying it, so basic flying advice isn't super necessary.
What are some things I should do right out of the box? For reference, I'm running a Galaxy S7 for the control, as my iPad 2 is not compatible. Whether it be app suggestions, tips, tricks, etc. please let me know what you all have learned!
Thanks in advance.
-Owen
Reactions: Mike_Flys
Welcome to Phantom Pilots! :)
Check out PhantomHelp.com. You'll find a link to download the Phantom manual in the "Must-Haves" section and lots of other useful tips there.
Another question too- I see that you have to activate your phantom on the app before flying. Does it matter that I bought mine use or will I be able to activate it?
I recently got the P34k as well. It's a nice airship. I also fell into the hobby on the syma x5c, funny. Look into threads here about problems people have had with the firmware updates. I've read some people having problems after updating to the latest. I have not had any problems with the firmware which i updated before my first flight. But it's something to look into.
Inspect your ship thoroughly before every flight, especially the first.
Try learning all the camera functions on the ground so you dont waste precious airtime just trying to find the shutter speed function or something which i did. If you turn everything on you can sit on the ground just using the app to figure out the menu functions. Making flying less stressfull when you're not trying to find the right menu in the sky on a windy day.
Most of all!! Never panic! Know your exit plans and keep calm in the event of problems. And have FUN!
Thanks for the advice!!
I didn't realize the x5c-1 was so popular as a starter. I had fun learning with mine, and its tough in a crash!
I use mine to exercise my dog (sometimes) up at a park near my house. She's caught it and bitten holes all over the thing and it refuses to break. Otherwise, I put mine on high mode and try to dodge poles, etc. to get used to flying. Super fun either way!
wow. phantomhelp.com has so much info! i didnt know what prop balancing is until now. that sounds kinda hardcore tbh! is balancing really necessary and how often?
Is it absolutely necessary? Not if you're using DJI props (which I recommend). They are usually pretty close to balanced right out of the box. If you like a well oiled machine, then balancing is something easy to do. I usually only balance mine once when I change to a new set.
Thanks in advance.
-Owen
4K is a great machine.
Suggestions:
- Start easy and safe. I used a big open playing field.
- Get familiar with RTH and what happens as the battery goes down to critical
- Then work on the waypoints feature, flying around point of interest, and the other modes
- Figure out how you are going to process the video
Good flying!
Reactions: Owen S
I agree with Richard on getting familiar with RTH. That is one thing I wish I would have done because on my first signal loss I panicked a bit. Before I fly I usually check consistency with all four motors and then hover for about 30 seconds to make sure everything seems stable. Always make sure your home point is accurate and your RTH altitude is based on the max height of any obstructions your flying around (so set it higher!).
Reactions: Owen S
jorge sanchez
