ITELITE DBS Antenna in heavy wifi interference area?
My P3S range is significantly curtailed in the heavy wifi interference area I often fly in - will the ITELITE DBS antenna bring a significant improvement to range? Thanks!
The DBS will definitely increase your range but will also definitely become more directional. I love my DBS. If you are surrounded by interference there's no tellin what you will get but it will be better then stock.
Reactions: dirkclod
The directional component will likely work to your advantage, as long as you keep the DBS properly pointed in the right direction.
