Itelite antenna....becareful
Make sure you have got the ribbon cable properly seated and it is not damaged. That thing has to be reinstalled very carefully and fully plugged in
You already said it worked with IOS so.... That proves the mod and antenna are working. The issue is with your android set up not the antenna. Start here:
Camera trouble shooting
Please try the following steps:
• Ensure you have upgraded all DJI products to their latest firmware. Check updated, plus the camera firmware
• Ensure you are connected to the wifi phantom-xxxx SID
. Check bluetooth be sure it is off
• Ensure your phone or tablet has been updated to the latest software.
• Ensure you have closed all other multi-tasking applications.
• Check the free space on your mobile device, it is recommend having at least 3GB available, less storage could be causing an issue.
• Try deleting the app from your phone and downloading it again.
• Reduce the preview framerate from 30 fps to 15 fps in the Settings of the DJI Vision app. Check to make sure you have the latest google maps and app.
Open and let it use your location and cache the map.
Then open the android app and verify all your settings. Let it use your data and location.
See what you get on the OSD now.
