ITE-DBS01.4 connection cables modification?
Range Extender Antenna ITE-DBS01.4 connection cables modification?
I am wondering if you could use a single
U.FL To RP-SMA male Cable to connect from inside the controller to the antenna connection instead of have to drill holes and mount the 3 connection on controller. Could you use a single cable to connect the controller to antenna and route the small wires through the original antenna hole. I believe these cables have the correct ends and is small enough and is compatible with all the requirements needed. Maybe fewer connections means less signal loss too?? I'm just trying to simplify the connections of the antenna.. Any thoughts are welcome. Thanks ahead.
muskansahu
